Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Waveguide simulation in fdtd solution › Reply To: Waveguide simulation in fdtd solution
February 21, 2023 at 10:32 pm
1nm change is too small, which is smaller than the manufacturing errors. You should use larger incerement, at the integer number of mesh size.
This is for FDE solver I believe. Next time please write a new post whenever you have questions different from the exisiting post.
