Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › › Reply To:
February 21, 2023 at 6:45 pm
peteroznewman
What direction is the rotation of the driven gear? Is it advancing against the moment on the other gear or is it retreating from the moment on the other gear? Those two directions of rotation will have a different reaction moment if there is a significant friction on the tooth contact. If the contact is frictionless, then the moment will be the same in each direction.
