Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Setting Up user groups to access academic seats through the flex server › Reply To: Setting Up user groups to access academic seats through the flex server
February 21, 2023 at 3:19 pm
Check the Flexnet Administrators Guide.
Look for: Options file.
This will allow you to implement licensing rescrictions.
But I do not believe you can restrict the number of cores per run unless you are using
the "anshpc" license.
