The Ansys Innovation Space website recently experienced a database corruption issue. While service has been restored there appears to have been some data loss from November 13. We are still investigating and apologize for any issues our users may have as a result.
Ansys Learning Forum Forums Discuss Simulation General Mechanical An internal solution magnitude limit was exceeded. (Node Number 2174, Body Solid Reply To: An internal solution magnitude limit was exceeded. (Node Number 2174, Body Solid
Claudio Pedrazzi
Seems fine to me, though I do not really understand the symmetry, since you fix everything.
But just for testing. If you substitute your remote displacement wiht a simple fixed constraint on that cylindrical surface, hopefully the problem disappears?  It would be a first hint.
