The Ansys Innovation Space website recently experienced a database corruption issue. While service has been restored there appears to have been some data loss from November 13. We are still investigating and apologize for any issues our users may have as a result.
Ansys Learning Forum Forums Discuss Simulation General Mechanical Modelling contact between reinforcement pad and shell/nozzle Reply To: Modelling contact between reinforcement pad and shell/nozzle
peteroznewman
Consider not using contact. In SpaceClaim, I assume the nozzle edge has been extended to meet the opening in the shell.
Extend the hole in the pad to touch the nozzle.
Project the outside edge of the pad onto the shell, then create a surface using the Blend tool (keyboard B) between the projected curve on the shell and the outer edge of the pad.
On the Workbench tab, use the Share button. The result is the nozzle, shell and pad are connected at the correct edges.
A conservative analysis would be to ignore any face-to-face contact between the pad and the shell.
