Ansys Learning Forum Forums Discuss Simulation Fluids Density of fluid affects the results and it makes the result wrong. Reply To: Density of fluid affects the results and it makes the result wrong.
Sounds sensible. I suspect it's a solver where the flow jet entrains too much material from one of the two outlets and then pushes it all out of the other.  What are you expecting to see?
