Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Density of fluid affects the results and it makes the result wrong. › Reply To: Density of fluid affects the results and it makes the result wrong.
February 21, 2023 at 9:44 am
You are correct. The gap is not fully closed. There is a little gap between two sides. Operating pressure is 101325 Pa.Â
Thanks
