Ansys Learning Forum Forums Discuss Simulation General Mechanical Interference fit Simulation Force Reaction Reply To: Interference fit Simulation Force Reaction
Akshay Maniyar
Hi Julien1998,
The reaction you are getting in the first load step is because we have constrained the hub in the axial direction and when the interference is solved there will be some axial displacement of the hub but it is restricted. Then the reaction in the second load step is the force required to pull out the hub by 5 mm.
Thank you,
Akshay Maniyar
