Ansys Learning Forum › Forums › Installation and Licensing › Ansys Free Student Software › Element has excessive distortion. › Reply To: Element has excessive distortion.
September 25, 2022 at 12:03 pm
Does it solve with NLGEOM turned off?
You might have a mistake in the model. Check the magnitude of the loads and check the values of the material properties. Check the thickness property of the shell element. Reduce the load by a factor of 10^3 and try that. Reduce the load by a factor of 10^6 and try that.
