peteroznewman
So you mean you are creating a spring element by selecting a node on one surface for the Reference on the first spring and a node on the second surface for the Mobile on the first spring. Then you repeat that 19 more times?
In that case, yes, you would divide the total spring rate you want between the surfaces by the number of springs and assign that value to each spring.
