Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Problem with partial overlap of solid and fluid domains in FSI simulation › Reply To: Problem with partial overlap of solid and fluid domains in FSI simulation
September 23, 2022 at 12:26 pm
Hi Judith,
When a co-simulation coupling participant, such as a Fluent system, is connected to a Mechanical
system via System Coupling, Mechanical is given access to data directly from the other participant. So, I would suggest you to create conformal mesh and specify the velocity at the extended part and transfer data directly from Fluent to Mechanical through system coupling.
