Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › spring combin14 › Reply To: spring combin14
September 23, 2022 at 11:48 am
Apparently I explained it wrong, in fact I wanted to link two surfaces by springs while each surface contains 20 nodes is it necessary to divide the stiffness by the number of nodes.Â
For example I take a 7N/mm spring so I need 20 springs so each spring has 7N/mm or each spring has 7/2
