Ansys Learning Forum › Forums › Discuss Simulation › Fluids › 2D Heat Flux › Reply To: 2D Heat Flux
September 22, 2022 at 1:38 pm
Essentially, as long as the reference depth is scaled appropriately - mass flow rate and heat flux should be the same in both 3D and 2D cases correct? I would agree that for the default depth of 1m mass flow rate would be different in 2D and 3D planar cases.Â
In this case we are inducing evaporation-condensation in a closed domain, the only boundary condition input is heat.Â
