Ansys Learning Forum Forums Discuss Simulation General Mechanical Boundary conditions problem Reply To: Boundary conditions problem
Ashish Khemka
If the four sides are fixed and if you are pulling the bar then the tension should be seen in the model. With force application, you may face a convergence issue.
Ashish Khemka
