Ansys Learning Forum Forums Discuss Simulation General Mechanical How to use script to run the cfile for creating k file? Reply To: How to use script to run the cfile for creating k file?
cct
I just downloaded the T005_trycube.k in LSDYNA/1.1, and it seems good, having the shell mesh and properties of material, hourglass, and section. This kfile is copied into 1.1 just 12 sec later than the lsopt runs. Is this issue be unable to solved with using queuing >simple?
