Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How to use script to run the cfile for creating k file? › Reply To: How to use script to run the cfile for creating k file?
September 21, 2022 at 10:18 pm
igandiko
Clearly, file copying failed which means either T005_trycube.k is not available in Stage/1.1 or it wasn't generated yet when ls-opt moved on to next step after running LSPP command.Â
