Ansys Learning Forum › Forums › Discuss Simulation › Fluids › DPM model VS DDPM model › Reply To: DPM model VS DDPM model
September 21, 2022 at 9:14 am
What did they normalise the data to in the paper? You're off by about the same amount until you hit the near wall, and you won't be the first person to have missed a (hidden) factor in published experimental data.Â
Re the concentration plots. Plot cell volume on the same line, I suspect it's a case of particles per volume being slightly off, rather than a problem with the results.Â
