Ansys Learning Forum Forums Discuss Simulation Photonics Can we choose material and core radius of optical fiber in Interconnect? Reply To: Can we choose material and core radius of optical fiber in Interconnect?
Guilin Sun
If you have import the mode profile in INTERCONNECT, you will be able to check it. Otherwise you will need to use FDE or FEEM to characterize the mode proerties. INTERCONNECT is not designed to do such things. However it can show whatever your input.
