Ansys Learning Forum Forums Discuss Simulation Fluids Issues running Fluent across multiple cores Reply To: Issues running Fluent across multiple cores
Amine Ben Hadj Ali
Bugs are always possible even in the post-processing module you are using. Check the results in Fluent first and let's know if you see issues there too. If yes then it has nothing to do with export!
