Ansys Learning Forum Forums Discuss Simulation Photonics Saving delta of two field profile monitors Reply To: Saving delta of two field profile monitors
kemackay
Hello, the two monitors have the exact same y and z dimensions, but are located a very small distance away from each other on the x propagation axis (200nm). The waveguide cross-section changes between these two monitors so the goal is to see how the field profile changes in such a short distance. The wavelength is the same for both monitors.
The dataset EM shows the original monitor data.
