Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Is it possible to update only one output parameter column in the parameter set? › Reply To: Is it possible to update only one output parameter column in the parameter set?
September 15, 2022 at 1:52 pm
Set each DP in turn as "active", right click on the blue column cells then (I think) you can open the Solver part of Fluent from the workflow. Otherwise you need to go into the Workbench folder and find the various Fluent files in the dp# folders.Â
How many cells in each model? How many real cores have you got? What is "slow"? The latter is because I'm used to models taking anywhere from 10minutes to several weeks or even some months to run.Â
