Ansys Learning Forum Forums Discuss Simulation Fluids Is it possible to update only one output parameter column in the parameter set? Reply To: Is it possible to update only one output parameter column in the parameter set?
You can't just update one parameter as the table is created from the runs, not data-mined. Assuming the case & data still exist you could manually extract the value(s).Â
