Ansys Learning Forum Forums Projects & Partners Kampus Merdeka lumbar motions simulations problem- in solid mechanic Reply To: lumbar motions simulations problem- in solid mechanic
aaron.nguyen
Hi Hendrawan Ariefudin,
It means the component Pressure_zero_nodes is not defined. Please follow the instruction video slowly, step by step.
In the Names Selections check pressure_zero_nodes. And make sure you add APDL command on Analysis setting part
Thanks
