Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Issue with Importing source › Reply To: Issue with Importing source
September 14, 2022 at 9:10 pm
Do you want to get the importd source data, or want to visualize the source data? Do you find any result in other monitor? Please make sure you save it correctly. you can close the import tab and reopen, then visualize the data to see if it is normal.
