August 3, 2022 at 11:58 am
01142385
Thank you for your quick reply. I would like to reduce the density of the mesh only at this specific location (marked in red), because then it creates problems whith boundry layers generation in the volume mesh. I would not like to reduce the proximity and curvature settings , because then I will reduce the mesh density at the trailing edge.
Is it possible to decrease detailing of geometry only at that particular location?
