Ansys Learning Forum Forums Discuss Simulation General Mechanical Contact Definitions Reply To: Contact Definitions
mertnarinn
After adding it to the list in the communication tool, it gave the following result. What should I do to find a solution here? As in the video, I throw the ball from the air towards the ground with the initial velocity. I am using exactly the same inputs.
