Ansys Learning Forum Forums Discuss Simulation Preprocessing is there any way to accelerate the manipulation in ICEM CFD ? Reply To: is there any way to accelerate the manipulation in ICEM CFD ?
Emma CFD
Thank you for the reply!
I actually failed to mesh my geometry using Mechanical, I am about to mesh A bend pipe with a rib in the extrados of the bend. I tried the multizone method, I split my geometry into several parts but nothing is worked so I decided to use the icem maybe it will generate the hexahedral mesh. Unfortunately, Icem refuses to work correctly for me!
here is my geometry:
