Ansys Learning Forum Forums Discuss Simulation Fluids Meshing with ICEM causes “floating point exception” Reply To: Meshing with ICEM causes “floating point exception”
Keyur Kanade
18.2 is very old version. Please try latest 2022R1 version.
Meanwhile you can check if you can import that mesh file in Fluent Meshing. Then you can check mesh in Fluent Meshing as well.
Regards Keyur
