Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Photonic Bandstructure Calculations › Reply To: Photonic Bandstructure Calculations
February 18, 2022 at 5:00 pm
schinta3
Hello
Thanks. I did notice this, however does this mean that the actual sweep ranges should extend all the way to 'a' with the correct units.
For example, if a=250nm, should the k values in the sweep be from 0 to 250
Or if a=0.250um should the k values in the sweep range from -0 to 0.25, sue to usage of SI units?
Best Sreyas
Best Sreyas
