Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How to perform mechanical simulation of a brittle cylinder? › Reply To: How to perform mechanical simulation of a brittle cylinder?
February 17, 2022 at 7:08 am
Thanks for your reply.
I would like to use SS 304. I have the following temperature-dependent properties
YoungÔÇÖs modulus, PoissonÔÇÖs ratio, Compressive yield strength, Tensile yield strength, Compressive ultimate strength, Compressive ultimate strength.
I would like to find the force required to fracture the cylinder under tensile and brittle conditions.
Thank you
Thank you
