The Ansys Innovation Space website recently experienced a database corruption issue. While service has been restored there appears to have been some data loss from November 13. We are still investigating and apologize for any issues our users may have as a result.
Ansys Learning Forum Forums Discuss Simulation Fluids Running a two-way intrinsic FSI simulation with non-conformal meshing. Reply To: Running a two-way intrinsic FSI simulation with non-conformal meshing.
johnhavenar
Thanks for getting back to me.
The fluid surface and solid surface were both meshed using a minimum size of 0.5 mm, a maximum of 5.0 mm, and a growth rate of 1.2. The difference was that the fluid volume used poly-hexcore and the solid volume was pure tetrahedral.
You mentioned that this was observed before, but I haven't been able to find anything on it. Could you possibly link me to the source?
I also tried creating a conformal pure tetrahedral mesh and exporting the fluid and solid to separate mesh files, loading the fluid domain, converting it to poly while preserving boundary layers (so it should still be conformal), and then appending the solid mesh to the fluid mesh and fusing them together. The fusing was successful and a wall - wall-shadow pair was created, but the analysis failed once iteration began.
John
