Ansys Learning Forum Forums Discuss Simulation Fluids Re: High aspect ratio Reply To: Re: High aspect ratio
Karthik Remella
Administrator
Hello In my opinion, this is a fair mesh. When you use a Y+ ~ 1 mesh, the aspect ratio of the elements in the BL is going to be high. In your case, did you plot the Wall Distance contours to double-check if you are seeing any anomaly?
Karthik
