Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Zero thickness wall inside the domain › Reply To: Zero thickness wall inside the domain
October 28, 2021 at 4:13 pm
NimaNZ
That's exactly the problem. What you're saying is that I should determine the body of that fin as fluid in Mechanical and only wall side as a wall? or just to be smaller than the grid side it cannot capture the effect of thickness and it can be solid?
