Ansys Learning Forum Forums Discuss Simulation Fluids Zero thickness wall inside the domain Reply To: Zero thickness wall inside the domain
The surface isn't passed into the Meshing tool as it's not recognised. The easy work around is to model the object with a relatively high thickness and only label one face as a wall. You mesh the thickness to be no finer than you'd model the bulk and sorted.
