Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Latent Heat In Fluent › Reply To: Latent Heat In Fluent
October 27, 2021 at 11:57 am
My latent heat is in J/kg. Right now I'm running with liquid SSE as 17500 and the vapor SSE as 0. I don't know should I multiply or divide it by some factor (maybe molecular weight). I'm running the condensation case.
I know the other way to do it is with the DEFINE_SOURCE macro. But, I'm already using DEFINE_MASS_TRANSFER macro and in new fluent, both these macros don't work well if used together.
