Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › Problem in creating hexahedral mesh › Reply To: Problem in creating hexahedral mesh
October 27, 2021 at 1:45 pm
Ansys staff cannot download files from forum. Someone else could take a look at the model and help you with this
See if Multizone method helps create a hex mesh
Sweep requires one source face to one target face. Source and target should have same topology. That is if source face has 4 edges, target should also have 4 edges. If you have additional splits, the body is not sweepable. Check in wireframe mode and display vertices to see if there are additional splits. Merge selected edges using virtual topology to remove the spilt. (You do not have to use automatic virtual topology)
