Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Calculation on Phase Interface using VOF › Reply To: Calculation on Phase Interface using VOF
October 28, 2021 at 4:03 pm
Turn the node values off and see what it shows. Also check the two sides of that surface are connected.
Black spots in post processing can be missing facets in the iso surfaces and doesn't alter the result. Also check that you've not fixed the scale and clipped to range.
