Ansys Learning Forum Forums Discuss Simulation Fluids RECIPROCATING COMPRESSOR VALVES – POROUS ZONE MIMIC Reply To: RECIPROCATING COMPRESSOR VALVES – POROUS ZONE MIMIC
And you're using superficial velocity in the porous media. Check static pressure too. I suspect the dP over the porous media is masking the results as the scale is very big.
