Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How does one perform proper transient analysis after a static analysis? › Reply To: How does one perform proper transient analysis after a static analysis?
October 26, 2021 at 10:21 am
Hi() Chris
One possible way (not sure since you use initial velocity if it will work, but it is the only way I know), is to
use transient for all, and the first part is the transient effects deactivated and in the final part add them on (TIMINT command).
See the above link/post that explains this flow.
Thank you
Erik
Thank you
Erik
