Ansys Learning Forum › Forums › Discuss Simulation › Fluids › I am trying to find heat transfer rate from radiator through fins. › Reply To: I am trying to find heat transfer rate from radiator through fins.
October 26, 2021 at 10:02 am
Assuming the flow over the fins is in the y-axis I'd restrict the outer domain so it's the same as the finned section in the x direction and extend in z and y.
