Ansys Learning Forum Forums Discuss Simulation Electronics Issue simulating an 400 element Reflectarray antenna Reply To: Issue simulating an 400 element Reflectarray antenna
Praneeth
I would like to suggest you to try reducing the passes in the adaptive meshing and see whether you are able to succeed or not.
Even though you have 382 GB RAM, the solver might need more based on the array size.
Try reducing the number of passes as trail and error and see the profile.
All the very best.
