Ansys Learning Forum Forums Discuss Simulation Fluids heat transfer coefficient inside a pipe with constant heat flux Reply To: heat transfer coefficient inside a pipe with constant heat flux
SV
Greetings
Please look at attached figure. Can we add surface heat transfer coefficient and try to plot it on a line on the wall to find variation of heat transfer coefficient as a function of z?
Thank you
Vafaei
