Ansys Learning Forum Forums Discuss Simulation Photonics Average temperature rise calculation in Diabolo antenna plasmonic heat generation Reply To: Average temperature rise calculation in Diabolo antenna plasmonic heat generation
niazulkhan
Thanks a lot, I understand how it was calculated= (illuminated area/total area)* (Tsim-300).
Total area was used as 85 um x 85 um, but I do not understand how this total area affects the simulation parameters in FDTD . If for example, the total area is 100 um x 100um, what change I will make in the FDTD or HEAT solver?
