Ansys Learning Forum Forums Discuss Simulation LS Dyna How to run a model at different temperatures using Johnson-Cook (J-C) MAT015 and MAT107 in LS-DYNA Reply To: How to run a model at different temperatures using Johnson-Cook (J-C) MAT015 and MAT107 in LS-DYNA
Andreas Koutras
For MAT_015 you can specify the initial temperature change T-Troom by using *INITIAL_STRESS_SOLID/SHELL and setting history variable #5. I'm not sure how well this will work. I think I would use the coupled analysis. Maybe you need to check your thermal solver parameters. Make sure that the units of the material parameters and thermal properties are consistent. It's better to stick with SI units everywhere. I hope this helps.
