Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › WELDING HEAT INPUT IN JOULES/MILLIMETER IN MECHANICAL APDL › Reply To: WELDING HEAT INPUT IN JOULES/MILLIMETER IN MECHANICAL APDL
October 28, 2021 at 9:32 am
Thanks All for the responses, as I can see there is no direct input of Welding Heat input in J/mm. Your advices are well acknowledged. I will follow-up with all advice and come around with solution.
Once again thanks to All.
