Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How to output the result of the corresponding time during calculation ? › Reply To: How to output the result of the corresponding time during calculation ?
October 25, 2021 at 11:30 am
Aniket
Do you want to set up specific substeps? https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v212/en/wb_sim/ds_establish_analysis_settings.html
or do you want to change the output to write the specified solution item every nth (and the last) substep of each load step? If you have the APDL command simply insert a command snippet under the analysis settings, and write your commands there.
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v212/en/wb_sim/ds_commands_object_sol.html
-Aniket
-Aniket
