Ansys Learning Forum Forums Discuss Simulation Fluids DPM drag force store in UDMI Reply To: DPM drag force store in UDMI
DrAmine
Just not use hybrid parallel method and it would work (as hybrid might require some more lines to avoid co-current processes writing in the same memory). I have a feeling you are just using the UDF without really understanding the whole issue: is this correct?
