Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Batch file command to monitor fluid property, report file, and plot on surface point in ansys fluent › Reply To: Batch file command to monitor fluid property, report file, and plot on surface point in ansys fluent
October 27, 2021 at 8:55 pm
Amruth
Hello Alain
If I already have a .cas and .dat file that contains the key parameters of the simulation ( surface point, time-step size, max iterations/time step, iterations within time-step, report files, report plots, animations of the Mach number contours) and if I would like to run this file on cluster, should I again specify separate commands to output the files for pressure and animations in the journal file?
I actually set-up the simulation on my personal desktop (windows) and have run it to a certain time-step. In this process, I autosaved the .cas and .dat files every 2 time steps with the above parameters. Ideally I want to just continue running the simulation from this point onwards on the cluster and want fluent to keep outputting the file containing the static pressure for the surface point and the animation files of the Mach number contours.
Thank you.
Amruth
Thank you.
Amruth
