Ansys Learning Forum Forums Discuss Simulation LS Dyna Which contact to set between 2d sph workpiece and shell tool for mechanical machining (LS-DYNA)? Reply To: Which contact to set between 2d sph workpiece and shell tool for mechanical machining (LS-DYNA)?
Andreas Koutras
Hello, have you tried *CONTACT_2D_NODE_TO_SOLID? Please see the *CONTACT_2D section in the manual. I hope this helps.
