Ansys Learning Forum Forums Discuss Simulation General Mechanical Preload gain during the solution for gasketed bolted joint Reply To: Preload gain during the solution for gasketed bolted joint
Akshay Maniyar
Can you share the images of your model setup, bolt pretension and the plot for preload, so that forum members can help you in much better way.
Thanks,
Amaniyar
